Jag har hittat "ett" ersättnings cdi till transalp 89-95
http://www.ignitech.cz/english/aindex.htm
SPARKER DC-CDI-P2
Programmable two channel capacitive ignition for motorbikes supplied by 12 V.
SPARKER DC-CDI-P2 ignition is a programmable two channel capacitive ignition with revolution and TPS regulation of the advance. This type of ignition is used for some multi-cylinder road motorbikes (for example XRV750, YZF-R6, CX500, GPZ305, some models GSXR ...). If the sensor system of customer's bike does not comply with SPARKER DC-CDI-P2 ignition, it can be adjust by means of special settings.
SPARKER DC-CDI-P2 ignition is equipped with two inputs for pickup, input for throttle position sensor, blocking input, input for clutch master, output for tachometer, output for fuel pump relay, output for gear shift light, inputs and outputs for servo etc.
Ignition is fully programmable by software DCCDIP2.EXE. Software included advance map or curve, options for blocking, revolution limiter, servo ... Software is conformable to TCIP4 software.
The ignition unit is in plastic box with 20-pin grey connector. Counterpart connector are supplied.
Recommended wiring (doc).
Recommended wiring (pdf).
For price see to price list.
We provide expert installation of the device in our specialized shop.
En firma i tjeckien som fixar och donar med mc.
Nån som varit i kontakt med detta tidigare eller rent av testat?
Dom vill ha; 152euro för den + en kontakt för 10 och frakt 22.80 = 184,80 euro i dagsläget = 1632,43.
